Gear shifting?
Old Sep 13, 2008 | 07:34 PM
HUNTER1's Avatar
Default Gear shifting?
My eliminator 125 has only 300 miles, sometimes I have to double clutch or open the throttle a little bit to shift to first gear, just first gear at a stop, is this normal? or is the oil used afftects the shifting? thanks
Old Sep 14, 2008 | 04:50 PM
The ride is new. Check the clutch cable adjustments and check for any binding. Double check your drive chain tension while you are at it. Too tight? Oil does play a small part in shifting through the gears but not in first gear only.
Old Sep 14, 2008 | 05:53 PM
HUNTER1's Avatar
It will be soon needing it's 600 mile service, I'll take it to the shop. I'm not very mechanical but will soon learn, thanks.
Old Sep 14, 2008 | 08:43 PM
motor_head_666's Avatar
+1 on drags advice - i had the same happen a few times - adjusted the clutch cable, tightened up the slack in the chain and gave it a lube up and problem seemed to solve itself
Old Sep 15, 2008 | 06:11 AM
HUNTER1's Avatar
Thanks, I'll give it a shot and see If I can do it.
ALifeAquatic
May 29, 2011 03:04 PM
2dardi
Ninja 250R
31
Oct 4, 2009 03:58 AM
osufireman
500 LTD
Mar 11, 2008 02:35 PM
hicktown
Mar 27, 2007 08:22 AM
metalmallet
Apr 3, 2006 01:08 PM
