Fuel Problems
Old May 16, 2010 | 10:57 PM
HSMustang's Avatar
Default Fuel Problems
I'm getting my Vulcan 800 back up after sitting for a while. I have cleaned the carb, cleaned the fuel tank, cleaned out all filters. They were pretty clean to start with. No dried gaskets and o-rings in the carb, all jet nozzles were pristine. There is fuel flow to the carb. I adjusted the throttles, checked the fuel service level, no adjustment needed. Still no gas to the engine. When I open the throttle and put a small amount directly in the intake, the engine will try and crank for a few seconds. Any suggestions on what else to check?
Old May 17, 2010 | 02:44 AM
jeffzx9's Avatar
Maybe a dumb question: are you sure it's fuel delivery? I'm wondering about spark. if you have fuel flow to the carb, and the float(s) are within spec, it's either spark or air flow. The Three Amigos...one of them is out of sync.
No gas to the engine....hmmmm, but you have fuel flow to the carb? Something isn't making sense.
Welcome to the forums. We love this troubleshooting stuff; at least I do. Keep us posted.
Old May 17, 2010 | 03:11 AM
Prom's Avatar
Yup, carbs are a pretty simple beast, not much to go wrong. If you got your idle jets, idle screws and mix screws set it should all work. Are you sure the bowls are filling properly?
Old May 17, 2010 | 03:20 AM
HSMustang's Avatar
JeffZX9,
I had previously checked the spark plugs and ignition coils. Both coils indicated with in the pickup coil inspection standard of 380-570 ohms. Additionally, I placed the coil lead with a ground to chassis and was getting a good arch. The last series of starts were with the air filter off where i could put some gas in the intake. The engine would fire for a few seconds until the gas i had put in the intake had been used.
Old May 17, 2010 | 03:22 AM
jeffzx9's Avatar
Check your floats. Sounds like it's not filling to the proper level or something???
Old May 17, 2010 | 03:32 AM
HSMustang's Avatar
Prom,
I had previously pulled the carburetor and checked all of the diaphrams. There were no worn or dried gaskets and I saw no gel inside the unit. After reassembly, I filled the bowl IAW the service fuel level check. That is the only bowl in the manual that is discussed. When I manually move the vacuum piston, it does not feel like it has any fuel in it (no resistance). I do not have a procedure in the manufacture's book that has the procedure to adjust the jets and screws. I did not change thier settings but will look for a procedure to check these.
Old May 17, 2010 | 05:30 AM
yeah, check to make sure the floats are set to the proper adjustments and verify synchronization. Good luck and welcome to KF.
454spyder
Aug 14, 2023 05:16 PM
AndrewGMoto
Jul 21, 2014 02:09 PM
bmrconstruction
Jan 28, 2009 11:23 AM
sal636
Aug 7, 2007 12:58 PM
alarmman15613
Aug 2, 2006 07:30 AM
