fouling plugs
Old Mar 24, 2007 | 08:26 AM
ekhatch22's Avatar
Default fouling plugs
I have a 1995 zx7 and i keep fouling plugs... i have hindle pipe the carbs have been tuned to the pipe. i just dont get it.... HELP!
Old Mar 24, 2007 | 09:00 AM
Default RE: fouling plugs
Need a better history than that!
Old Mar 24, 2007 | 06:19 PM
ekhatch22's Avatar
Ok better story. My bike will start fine and ride fine for a while. Then it will start missing just out of the blue. Ive put new plugs in and wires but i still get a miss.can someone tell me how to lean the bike out a little
Old Mar 25, 2007 | 03:14 PM
ninjabarmy's Avatar
Don't always assume it's a mixture problem.Yes check the usual things like clean air filter and carb float levels etc but don't forget that bad ignition means unburnt fuel causing misfires. Do you have a healthy blue spark at the plugs? Is the battery good? Etc.
Old Mar 25, 2007 | 04:58 PM
exactly. At what rpm's and engine loads does the "miss" occur?
Old Mar 26, 2007 | 05:30 AM
Lyn125's Avatar
i use to have this problem ALL THE TIME..
very annoying to keep replacing plugs. I went through a lot of steps til I found the cause of it all. Not to say you would have the same outcome, but I'll give you some ideas on where to look..
I would be sure my carb was clean, check the floats and clean or replace the air filter as ninjabarmy suggests. when i had this problem I changed my mixture too on first instinct, but it didn't help. It wasn't until I took my engine apart for the winter that I noticed my cylinder is completly infested with carbon! i mean nasty. (first time i took it apart)
I dont know what your matinence shedule is like, but dont forget all the places carbon can build.
so I suggest do what's simple first, look through your manual if you have one to troubleshoot, make sure all is clean, check your compression, and good luck.
RobG
Oct 7, 2014 12:20 AM
seizetheday4eva
Aug 14, 2012 04:25 AM
ryeshelman
Apr 8, 2008 08:00 PM
Hoss
Mar 22, 2007 06:48 AM
vince
Jul 3, 2006 05:37 AM
