Forum please help! zx600 rebuild
Old May 31, 2009 | 09:26 PM
isaacpinnacles's Avatar
Default Forum please help! zx600 rebuild
Idle wont hold...haven't adjusted the carbs on this rebuild. However I have to plug them with rags to get it to start pretty much. i think I barely got it started once or twice today without them while the bike was still warm. theres a slight exaust leak nothing major. i have to get a new bracket for one of the pipes. Bikes staged all the **** blowing out white smoke all over hahhahahah
If anyone is listening and can help thank you...
isaacpinnacles
ps. only diff is the 1/2 mm overbore +pistons and rings...Do you think valve clearenceshould be changed or double check my specs with head shop that reassembled it? Just a few more thoughts b4 I go. peace
Old May 31, 2009 | 09:51 PM
tough call since a newly started motor may have some smoke from assembly. But not from what you mentioned. How was your cam chain and crank mark position when you assembled the engine? etc. Get the basics rolling first and back track some if needed, the carbs could have been screwed up on the shelf time as in removal and installation. check your plugs etc.
Good luck
Ninjaattack
Mar 23, 2010 04:44 AM
isaacpinnacles
May 31, 2009 09:52 PM
isaacpinnacles
May 31, 2009 09:22 PM
WestOzKLX
Apr 21, 2008 07:23 PM
oldskoolninja
Jul 11, 2005 01:12 AM
