Zxr 750 carb balancing......
Old May 31, 2009 | 07:56 AM
mrparishboy's Avatar
Default Zxr 750 carb balancing......
Hi all,
I need some help.... I've just finished cleaning and need help balancing my cabs on my ZXR 750. I'm gonna balance em the old way, (clear tubing with oil). What I need to know is, do I start on the side with the throttle and sync the others from there??? Or visa verse???? Also I have a blank on one of my air intake on the carb, when balancing, do I swap the blank with a hose connection that I'm not using get it in sync and swap back again??????
I also changed all the fuel lines and the filter, when it comes to putting the tank on I have forgotten which hose goes where??? Underneath the tank there's two hoses marked by color's, (yellow and brown). I know one is air and the other's fuel and I can see where there meant to go but don't know which is which????????
If anyone out there can help, it would be much appreciated.....
Thanks......
Old May 31, 2009 | 03:49 PM
https://www.kawasakiforums.com/forum...ad.php?t=19450 check here
here are a couple of pics anyways from my 91 but there are also 96-2002 pdfs in the above link.
Float heights for the J are 13mm +/- 2mm
Float heights for the K are 9mm +/- 2mm
Old May 31, 2009 | 03:52 PM
what hose info I have
Old Jun 1, 2009 | 07:51 AM
Dragone,
Thanks for your speedy reply. The info you gave me on balancing my crbies was very helpful.
I still cant figure out brown and yellow hoses under the tank?? I think one is for the reserve and the other's the main fuel..?? I see that they plug into the fuel on, off and reserve unit.. Again, don't know which is which??????? Any help would be much appreciated..... Thanks....
greenzxr750j1
Apr 21, 2010 11:53 AM
Daishag
Nov 28, 2008 06:48 PM
chris322
Nov 12, 2007 06:38 PM
simes
Aug 8, 2007 08:03 PM
RDSaxon
Ninja ZX-7R
Jul 28, 2007 10:55 PM
