ex500 will not start
Old Aug 4, 2010 | 06:15 PM
ghostrider214's Avatar
Default ex500 will not start
so im riding down the road and notice i am having power loss and clutch problems. then i pull into a parking lot and i died and will not restart. has anyone had this happen to them? please help
Old Aug 4, 2010 | 07:43 PM
94Ninja250's Avatar
Does it crank, but not fire? Or no crank at all?
Old Aug 5, 2010 | 12:33 AM
^ +1, and is the fuel on? Did you happen to hit the kill switch by accident?
Welcome to KF and good luck.
Old Aug 5, 2010 | 02:54 PM
got it home and starter tries to engage but wont turn the motor over battery is charged pulled the drain plug and oil smells like gas
Old Aug 5, 2010 | 03:56 PM
jeffzx9's Avatar
I would not assume the worst.....yet. Might be something as simple as gas getting into cylinders/crankcase due to faulty petcock; leaving in "prime" position, or weird overflow. Had a Suzook do this with an aftermarket petcock, once. Flooded the crankcase with fuel.
I'd suggest changing the oil, pull a spark plug or two and manually turn the crank to check for binding/noise, check your clutch pack, and basically make sure "systems" (i.e. charging/starter, compression/c-case, clutch, driveline, etc.) are individually intact. Reassemble and re-connect. Report back to us; glad to help.
Old Aug 5, 2010 | 06:54 PM
i did as you said and manually turned the engine over, it turned over pretty easily without any binding and so it tried to start it again an walah it fires rite up. now i just need to check the carbs? could it be the needle valves leaking causing the flooding of the cylinders? anyone have a manual available for sale?
Old Aug 5, 2010 | 11:35 PM
There is a pdf EN450 manual and a EX500 supplemental online. I prefer using hard copies personally. I think that I got mine from ebay
Old Aug 6, 2010 | 11:17 AM
thanks for all the info peoples. i got the carbs and the petkok rebuilt so hopefully no more gas in the cylinders. fresh 20-50 and the 2000 500r runs like a champ. 7850 miles on the clock. i will check ebay for the manual. ride on
cegusman
Sep 25, 2012 02:08 PM
Jake Rihaly
Sep 2, 2010 11:45 PM
IQOUTLAW
Mar 23, 2010 02:33 PM
horizonod
Jan 16, 2009 12:11 PM
