cam shaft spocket
Old Mar 6, 2013 | 02:44 PM
deeppowder's Avatar
Default cam shaft spocket
Is it visually possible to see if a cam shaft sprocket has spun on the cam shaft? If not, how else would you know?
Thanks.
Jeff
Old Mar 6, 2013 | 05:02 PM
Thanks.
Jeff
Of course you can. The two bolts on the sprocket would be sheared off.
Old Mar 7, 2013 | 02:02 AM
deeppowder's Avatar
Thanks for the reply dragone. Just so I am on the same page, apparently this happened on my friends 08 KX250F (same bike I have and trying to understand what happened). All I have to look at is a PDF of the 06 service manual and I don't see the two bolts you mention that hold the sprocket to the cam. Is my PDF not applicable to the 08? If you don't mind, can you explain the two bolts?
Thanks.
Jeff
Old Mar 7, 2013 | 05:39 AM
My bad. I was thinking you had a street ride for some reason. So I do not have an answer for you. Sorry about that.
Old Mar 7, 2013 | 03:02 PM
deeppowder's Avatar
No worries. Anyone else have any thoughts?
Thanks.
Jeff
MaxxRonin
Jul 9, 2010 08:12 PM
frankb
Mar 17, 2010 03:19 PM
buff36
May 30, 2009 01:12 PM
aszrael1266
Mar 6, 2007 08:05 AM
atcnga
Sep 18, 2005 10:19 PM
