Brakes?
Old Oct 4, 2008 | 03:55 PM
HUNTER1's Avatar
Default Brakes?
I lift up my front tire to try my front stand and I spin the tire and the pads are touching the rotor very slightly, not stopping the tire or I don't think it's slowing it down signiificantly. The bike has less than 500 miles. Does it just need adjusting or the pads just need to be seated more? I will be taking it soon for 600 mile service. I'm not experience to be adjusting anything just yet, thanks.
Old Oct 6, 2008 | 06:26 AM
whitehendrix's Avatar
they all do that. if theres significant resistance, then ya.. you migt have a problem, but if it'll rotate a few times under mild spinny pressure, then you're good.. you can feel if theres a problem. should have nice travel and feedback in your lever under low and high loads and speeds, and if a trip around a few blocks reveals severe heat (don't use the front on the test.. just the back brake) then you've got a pot hanging up somewhere.
should make a very light noise from the rotors while spinning by hand.. no grinding, discoloration or heavy streaking, squeaks.. none of that.. lol
i think you're good, bro. new bike i'd assume.. everythings minty fresh and tight on a new bike. nothin to worry about unless the aforementioned has manifested.
Old Oct 6, 2008 | 10:23 AM
williamr's Avatar
Apart from a little inherent springiness in the caliper seals and boots (if fitted) there's nothing to pull the pads away from the disc. Air flow over the disc pushes them back a little at speed, but only just about enough to clear. Pads need to be very close to the disc to minimise lever travel.
Rob
Old Oct 6, 2008 | 03:13 PM
zzrick's Avatar
I agree with these guys, it sounds normal to me.
Old Oct 7, 2008 | 03:27 PM
HUNTER1's Avatar
Thanks guys, this is part of my learning experience in motorcycle world.
Funkdock
Jan 30, 2006 12:03 AM
xmxracer
Nov 7, 2005 03:01 PM
MAD KAW
Oct 11, 2005 07:53 AM
ntence
May 11, 2005 04:25 AM
Raymer626
May 6, 2005 03:47 AM
