both handlebars are hitting the gas tank
Old Nov 23, 2007 | 08:03 PM
Syn's Avatar
Syn
Default both handlebars are hitting the gas tank
ninja 250
the wheel is straight and the handlebars are lined up, but they both hit the gas tank when turned. any idea how to fix this? thanks
Old Nov 23, 2007 | 09:47 PM
markmeinteil's Avatar
Default RE: both handlebars are hitting the gas tank
Sounds like the fork rods need to be adjusted
Old Nov 23, 2007 | 09:51 PM
Actually, I'm not sure if that's right. I can't remember what the 250 setup looks like. will check it out tonight if nobody else has a better answer.
Old Nov 24, 2007 | 02:06 AM
jeffzx9's Avatar
Are they clip ons that bolt onto the forks at the triple? If so, they may be adjusted inward too much. They probably have an allen head bolt in the clamp area. Loosen the allen bolt(s) and rotate them outward. Just measure to make sure they're even. If they're actually "bars" I'm probably not the best resource.
Old Nov 24, 2007 | 03:16 AM
Thought that the "clip ons" were bolted onto the triple tree on the 250?
Old Nov 24, 2007 | 05:49 AM
dilysi's Avatar
the two bolts ber bar loosen them then push away from tank snug them down then tork to spec then repet for oposit side. the book has the prosess it is worth its weight in gold
klx250s_rider
Nov 15, 2007 09:15 PM
BlazingOrange
Ninja ZX-7R
Oct 15, 2007 12:19 AM
CRAZY
Oct 7, 2007 08:35 AM
ChrisBoom
Sep 14, 2007 04:50 AM
recker59
Aug 31, 2007 01:48 AM
