Bike not starting? (tick tick)
Old Jan 31, 2007 | 10:17 PM
Trelaboon's Avatar
Default RE: Bike not starting? (tick tick)
Thanks for all the replies folks, really glad to see them.
As for push starting it, I did try that, and it was a no go.....The bike would semi start up for just a second and it would die almost as soon as it started....So that's a no go
I'm going to go out this weekend and check on all of my connections and what not. I'll let you know how it turns out...
Thanks alot!
Old Feb 1, 2007 | 12:56 AM
Notstock's Avatar
ORIGINAL: Trelaboon
Thanks alot!
Sounds like its not getting feul, is the feul line open?
Old Feb 1, 2007 | 06:23 AM
my98_500r's Avatar
same thing JUST happened to me the other day, was the battery gone bad. Same symptoms.
Old Feb 1, 2007 | 06:35 AM
evil636's Avatar
Knee Dragging Pimp
there is no fuel switch on our bikes. is there fuel in it ? possible the lines were put on backwards too.
Old Feb 4, 2007 | 12:52 AM
Trelaboon's Avatar
Yes, there's fuel in the bike, I rode it home after it was repaired at the shop, I went out to start it a couple days later and this is what was going on....I don't see how a battery dies in 2 days though? and when I charge it, it says "Battery Charged" so it must be some sort of wiring connection like you've said or something?
Old Feb 4, 2007 | 06:59 AM
Trel, you are saying that you do not have a volt meter to check this? After fully charged, the battery is prolly like 12.7-14 volts. If the key is in the off position, keep your leads on the battery. Does it drop in volts?
edit: sorry, use a volt meter. I maybe did not specify too clearly.
Lancaster90
Mar 15, 2012 12:46 PM
RayTard
Aug 9, 2011 02:00 PM
bike_demon
Oct 31, 2007 05:46 PM
CRAZY
Sep 25, 2007 07:15 PM
Marcus33
Mar 26, 2006 10:12 PM
