backfiring
Old Aug 14, 2006 | 03:58 AM
rickyzx's Avatar
Default backfiring
had my 94 zx9r backfire when trying to start it last nigh. evry once in a while stars fine after a long ride, but when i put it in gear and give it gas it stalls. usuually takes a few minutes to get it started and running fine again. but last night when it did the same i tried to give it gas and it backfired. agtyer again restarting it it ran fine.
what would cause this problem?
rick
Old Aug 14, 2006 | 07:08 AM
Default RE: backfiring
At the moment, sounds like it starving itself of fuel. Like the emulsion tubes may be plugging up. Try some choke (after it is started)and see what happens.
Old Aug 15, 2006 | 09:37 AM
rickyzx's Avatar
thx for the info. i'll try that next time.
Old Aug 15, 2006 | 06:47 PM
Bluebeast's Avatar
To me it sounds like it's flooding it's self. Maybe you need to sync your carbs maybe that would help you out.
Old Aug 16, 2006 | 06:52 AM
So true Bluebeast. Just wanted to see what happens on an easy tryout in running before seeing the plug chop.
Old Aug 17, 2006 | 09:22 PM
rickyzx's Avatar
it does need to be tuned. i'm sure it'll run that much fater when done.
Barnett22
Aug 6, 2008 01:35 PM
chucktowngreen
KLX300R
May 18, 2007 02:23 PM
chucktowngreen
Apr 28, 2007 12:41 AM
gmilbu
Feb 16, 2007 01:52 AM
twenty4valve
Jun 5, 2006 08:32 AM
