94 zx7 not starting issue
Old Aug 15, 2013 | 12:28 AM
josh_3010's Avatar
You sure all 4 cylinders are running? Spray some water on the headers to see if all 4 are heating up.
Old Aug 15, 2013 | 12:38 AM
Havok_96_2008's Avatar
yeah all four are running i can tell i think i put the floats in backwards cuz it seems something is backwards open throttle and it dies but it runs on idle...
Old Aug 15, 2013 | 01:01 AM
josh_3010's Avatar
It was running ok when you parked it wasn't it?
Old Aug 15, 2013 | 01:06 AM
yeah other then i ran it out of gas it was running great
Old Aug 15, 2013 | 01:11 AM
josh_3010's Avatar
It sounds like something is wrong with the pilot circuit. Were you able to blow air through the carb body where you took the pilot jet out? Sometimes the carb body itself is blocked. Were you able to get a small piece of wire through each pilot jet?
Old Aug 15, 2013 | 01:31 AM
didnt need to i can see clearly thru them im changing the floats again im almost sure they are in backwards
Old Aug 15, 2013 | 01:39 AM
josh_3010's Avatar
Sorry man, wish I could help more. Hope you get it straitened out.
Old Aug 15, 2013 | 02:41 AM
i dunno still no luck changed the floats i have a video of it i can post to show
Old Aug 15, 2013 | 02:50 AM
Old Aug 17, 2013 | 09:13 PM
problem solved main and pilot jets plugged got the kawasaki dealer cleaned them quick for me
