94 zx7 not starting issue
i cant this to start i have changed plugs, cleaned fuel filter check the fuel pump everything seems to be working but i cant figure out whats causing the not starting problem any ideas?
Has youre bike been sitting for awhile? If so how long? Or did it quit while you were riding?
not long a few weeks i ran it out of fuel, bled the fuel line to remove the air then check to the carbs the pump works and pushes out fuel replaced the spark plugs but it wont fire
Do you mean the plugs have no spark, or the motor won't hit at all?
its trying to spark i used carb starter it fires up and dies im thinking im gonna have to rip out the carbs and clean them or the main feed line has something it it
pull the carb rack, do a thorough cleaning since you ran out of gas. Check the synch afterwards just to make sure. Careful on the either, it will damage/wash away oil from the cylinders.
Sounds like you're carbs are stopped up. I've seen it happen in as little as a month. Make sure you take the pilot jet out of each one, hold it up to a light and make sure you can see through it, if not use a bristle from a wire brush to open the jet back up. If you can, blow compressed air through the carb body where you took the pilot jet out
thats what i didnt want but i guess im gonna have to do it. again for the third time this season :( thanks for the input
i guess im gonna have to do it. again for the third time this season :( hahaha, you are a Pro at it now. |
ok update carbs cleaned pretty good looking replaced them bike starts on the choke will idle then it dies when i try to open the throttle? im out of ideas now any help?
