2020 KLX230R to soft front forks
Old Jun 17, 2020 | 03:10 PM
davet's Avatar
Default 2020 KLX230R to soft front forks
I own a 20 klx230r, I like the bike as is (stock) my issue is the front forks are way to soft. The issue is every time I go into a turn either in the woods or on a mx track the front compress to where the front tire hits the fender. It should be noted i did go up one click in the rear from stock. I ended up breaking my wrist to where I needed a plate and seven screws. I have been searching for stiffer front springs. Anyone have the same issue or found a fix for this issue? I am about 200lbs and had my friends who are around 160lbs ride and the front dose the same to them. I have been told to try and make a longer spacer out of pvc or higher weight oil. I don't want to blow out the seals or springs by trying those ideas. Please help!
Old Feb 9, 2021 | 04:18 AM
Ridgewooddirtrider's Avatar
Did you figure out anything on this? my 120 pound son has the same issue we just bought the bike.
Old Feb 9, 2021 | 02:43 PM
You won't blow out seals. If it was going to do so it would have done it under full compression. Spring preload a bit may work, but do not want to put in so large a spacer as to hit coil bind - coils completely compress.
Check this google search out - KLX230 suspension upgrades You should find what you want, heavier springs, for about $130 or so and well worth it.
DitchPickle
Apr 12, 2017 12:09 AM
Arctra
Jun 25, 2010 11:46 PM
truex14
Feb 22, 2010 09:05 PM
nosneb69
May 13, 2008 11:43 AM
rtanis3
KX125
Jul 27, 2007 07:48 AM
