front forks
Old May 9, 2008 | 06:22 PM
nosneb69's Avatar
Default front forks
hi to all, once again asking questions that I know are already posted but I cannot find them. So.......whats everybody doing the front suspension..? I just cannot take bottoming out all the time and it time to fix it. Has anybody tried theinstallationthemselves?
is it better to just change the complete fork to KX or something or to do the up graded prings etc...?
cheers
Old May 9, 2008 | 08:00 PM
jsac's Avatar
Default RE: front forks
i weigh 165 lbs.. dont do sick air but i do hang some, enough that i thought i broke the damn bike in half a coupla times. i dropped in .44kg springs. for me they are near perfect now. not stupid stiff and uncomfortable on the slab but they can take some hard landings now.
Old May 10, 2008 | 12:54 AM
2k1w=no$'s Avatar
I only did the springs too. Some have sent them out for revalves as well. It really depends on what kind of riding you are doing and fast/hard you are pushing the bike.
Old May 10, 2008 | 02:29 AM
gerrynolan's Avatar
I adjusted the clickers in and can take some higher jumps now. I guess the higher you get the heavier the springs need to be.
Old May 10, 2008 | 08:51 AM
The Mekon's Avatar
I have done most of the mods you have done so far + .42 springs for my 155lb frame. This plus 10w oil in the forks made a big difference to the front.
Old May 11, 2008 | 02:18 AM
oldphart's Avatar
Banned
yeah proper springs for your weight and decent oil will do the trick, unless your Roger Decoster then your on the wrong bike.
Old May 11, 2008 | 03:01 AM
nosneb69's Avatar
so, when you mean just springs.......just open the top of the fork remoave the old ones and replace with the new ones....?
is it that easy?
Old May 11, 2008 | 03:30 AM
nosneb69's Avatar
so I am about 185lbs, where did you guys buy your sings from....?
Old May 11, 2008 | 07:38 PM
Sid Post's Avatar
Is the spring swap something reasonable to do at home with limited tools?
Old May 12, 2008 | 04:05 PM
bryantjt's Avatar
Couple people have done write ups with pics. Do a search of this forum with the title fork springs and you should get results.
