2007 Klx 250 Electrical Issue
Hi all.
I'm having an electrical issue with a klx 250 I recently purchased. I believe I have narrowed the problem down to the ignition switch, but wanted to double check with you folks before I go drilling out the security bolts.
Works:
Both sets of blinkers work as they're supposed to.
Brake light works properly when the foot and/or hand lever is used.
Doesn't Work:
Headlight, both high and low beam.
Tail light
Liscense plate light.
All bulbs are fine. Disconnected the ignition and directly connect the power supply pin the the non-switch side of the connector to the headlight pin and the headlight turned on.
Am I overlooking or missing anything?
Thanks in advance.
Works:
Doesn't Work:
Tail light
Thanks in advance.
