2 stroke help
Old May 2, 2010 | 01:11 AM
rosco125's Avatar
ok about the spark. how do i adjust that ao give it more spark? i am goin to check compression sunday. what would be a sign that the rotory valve disk is bad. cracks?
Old May 2, 2010 | 06:18 PM
MaverickAus's Avatar
Don't know how to give it more spark, apart from replacing any faulty components. Check the rotary disk for cracks, chips and nicks, anything that could mean a leak.
Old May 3, 2010 | 07:44 PM
rosco125's Avatar
i checked the compression and couldnt get it to build over 105 lbs.
Old May 4, 2010 | 09:32 AM
That's gunna be a problem
Old May 4, 2010 | 08:27 PM
rosco125's Avatar
yea i thought so too. gonna try to put rings in it and hone the cylinder. i found all the parts i need on ebay for pretty cheap. im going to tear into er this week and see what all is wrong. hopefully just rings.
Old May 5, 2010 | 12:20 AM
rosco125's Avatar
is there any thing else i should replace while im putting in rings?
Old May 5, 2010 | 06:21 AM
might need piston, gudgeon pin
will need gaskets and gudgeon pin circlips (if you remove piston)
Old May 6, 2010 | 08:27 PM
rosco125's Avatar
i pulled the engine apart last night and all looked ok but im going to rering it and put new gaskets on it then check compression again.
Old May 17, 2010 | 08:37 PM
rosco125's Avatar
ok i got the engine all back together installed and got it runnin. it will run with the choke now as it would not before. it still wants to die on me when i go to take off. i can rev it up and let out on the clutch and it still falls on its face. dumb question, could it be that since i dont have a battery on it that its not getting enough voltage to run?
Old May 18, 2010 | 02:41 AM
jeffzx9's Avatar
Some 2-smokers use a magneto; is that what you mean?
