2 stroke help
Old Apr 29, 2010 | 01:37 AM
rosco125's Avatar
Default 2 stroke help
Hey guys i have a ke 125 im having problems with. It will start and run but when u put it in gear and try to take off it will die on you what could it be?
The plug when you take it out after you let the jug get hot looks light to medium brown. good or bad. Also do any of you know what a good compression reading would be? Thanks for the help
Old Apr 29, 2010 | 01:45 AM
Does it shut off when put in gear? If so check the side stand switch if it has one. My KLX had a sticky side stand switch. I took it off.
Old Apr 29, 2010 | 03:10 AM
even with the rpms reallly high?
Old Apr 29, 2010 | 03:17 AM
Generally it is the slow circuit in the carb or a cracked boot. What year do you have?
welcome to KF
Old Apr 29, 2010 | 09:52 PM
rosco125's Avatar
its a 1981 model. i replaced the rubber boot for the carb. i did ride it down the street and after a couple of runs it will idle but when givin thrttle it wants to die.
Old Apr 29, 2010 | 09:53 PM
rosco125's Avatar
also its a rotory valve engine. in case you didnt know.
Old Apr 29, 2010 | 11:02 PM
MaverickAus's Avatar
will it run with the choke on?
Old Apr 29, 2010 | 11:22 PM
rosco125's Avatar
no it will fire up and idle up for a few seconds and then it will die. then its hard to get started back.
Old Apr 30, 2010 | 05:22 PM
Williamexpamemum's Avatar
Hey dj, just hoping I can catch your eye sent you an email.
For some reason Share It would not take my aol email for delivery and I used a secondary one but I must have messed it up as nothing has come. Can you check your 'support' email, I sent the particulars there.
Then you can delete this topic, thanks ;- just trying to increase my odds at catching you over the weekend
cash quick | loans
Old May 1, 2010 | 04:10 AM
Sounds like it is lacking in fuel, maybe float height, maybe the fuel filter clogged (it's inside the tank), fuel line clogged?
Either that or lack of spark. Could be enough spark to get it going but not enough when the load comes on.
Compression should be approx 160 - 180 lbs/sq inch
Is the rotary disk valve ok?
