2 problems
Old Aug 3, 2007 | 10:32 PM
andsome1422's Avatar
Default 2 problems
I just replaced my battery and my bike will run for just a little while then the spark plugs stop going. second problem iswhen i got my bike it didnt have a speedo cable, i put a new one on and thespeedometer still doesnt work i dont have that much experience onthese problems so dont give me the beniefit of the doubt and over look a simple answer that i might have. thanx for any help
Old Aug 3, 2007 | 11:32 PM
aszrael1266's Avatar
The Dude
Default RE: 2 problems
What model bike is it? Does it have a digital speedo? could the speedo it selt be broken? with the battery are the cabels on nice and tight?
Old Aug 4, 2007 | 12:25 AM
1995 ninja zx7 the battery and cables are good the speedo is not digital and it might be . If the cable is new and pefect does that mean it is probly the speedometer itself?
Old Aug 4, 2007 | 03:00 AM
i think the battery is just not getting a charge and the bike is running solely off the battery but it deosnt have an alternator so what is the equivalent? as for the speedo thats on you guys that are bike studs!
Old Aug 4, 2007 | 06:55 AM
markmeinteil's Avatar
All right, let me take a stab at it.
Since you have a mechanical cable from the front wheel to the speedo (as I understand you saying), First check your speedo output drive on the hub. Remove the speedo cable from the speedometer head, with the inner drive shaft visible, roll the bike forward and see if it rotates. If it doesn't, your speedo drive hub is bad and needs to be replaced. If it does, you better start looking for a new speedo head.
Your second problem is more of a shot in the dark. I would be guessing either the CDI box, or the ignition pickup assembly is acting up on you. The main ignition coil can also quit sparking once it gets hot. Run the bike until it quits on you, then immediately remove a plug wire, stick a paper in the boot allowing the other end of the clip to be really close to the engine block, and crank the engine over. Do this for every plug wire, and watch for spark. If it does spark against the engine, you likely have a fuel delivery problem. If it doesn't spark, you'll have to narrow it down to one of the ignition components.
Old Aug 4, 2007 | 09:24 AM
ORIGINAL: andsome1422
You do not have an alternator? Take a peek....
jstroudzx6
Apr 29, 2021 07:31 AM
bmrconstruction
Jan 28, 2009 11:23 AM
problemvulcan
Nov 2, 2005 03:25 AM
Neotrion
Jun 19, 2005 04:09 PM
nemethjames1
Apr 22, 2005 07:50 AM
