Power Commander
Old Aug 2, 2007 | 01:48 PM
BigO's Avatar
Default Power Commander
OK I have heard a lot about the power commanders but what is it that it actually does. I have heard it takes a bit of hesitation out of the throttle and gives you better response time. Do you also have to change the exhaust when buying one?
Old Aug 2, 2007 | 02:38 PM
Kohburn's Avatar
Default RE: Power Commander
essentially it is a piggyback computer that lets you override the factory settings for fuel delivery and spark timing.
http://www.kneedraggers.com/details/...--19-DJ-4.html
they've got a pretty good write up about it.
Old Aug 2, 2007 | 02:54 PM
BigO's Avatar
Thanks KB. Again lazyness to do a google search. I need to get out of this mood
Old Aug 2, 2007 | 05:34 PM
markmeinteil's Avatar
It's just an excuse to be a post *****. We all post stuff we could easily look up.[8D]
Old Aug 3, 2007 | 01:28 AM
mmi86's Avatar
haha +2 mark, the Pc is a cutting edge state of the art computer mounted system to heighten your motorcycle needs ( damn damn, i should work for PC), it allows you the rider to tell the Ecu how you want it to act, you can do everything from change Air/fuel on a given Rpm at a given gear, or simple download one of their full set maps for free off of Dynoject.com, it allows use the consumer to either richen or lean out the system, "lean and green are mean machines" more or less, go go fast fast
Old Aug 4, 2007 | 09:41 AM
Ah hell, just get the khi setup if someone can tune it. The wide band looks pretty cool though on the DJ
arrowwhead
Jan 19, 2006 01:31 AM
arrowwhead
Jan 8, 2006 05:56 PM
eztalking
Sep 23, 2005 11:11 PM
fender780
Sep 7, 2005 06:36 AM
ntence
Apr 16, 2005 03:03 AM
