Power Commander
OK I have heard a lot about the power commanders but what is it that it actually does. I have heard it takes a bit of hesitation out of the throttle and gives you better response time. Do you also have to change the exhaust when buying one?
essentially it is a piggyback computer that lets you override the factory settings for fuel delivery and spark timing.
http://www.kneedraggers.com/details/...--19-DJ-4.html
they've got a pretty good write up about it.
haha +2 mark, the Pc is a cutting edge state of the art computer mounted system to heighten your motorcycle needs ( damn damn, i should work for PC), it allows you the rider to tell the Ecu how you want it to act, you can do everything from change Air/fuel on a given Rpm at a given gear, or simple download one of their full set maps for free off of Dynoject.com, it allows use the consumer to either richen or lean out the system, "lean and green are mean machines" more or less, go go fast fast
