1994 kdx200 is a complete mystery please help
Old Jul 5, 2018 | 11:57 PM
Riley Peterson's Avatar
Default 1994 kdx200 is a complete mystery please help
My 1994 kdx200 will not run it will fire off once in a blue moon run for like 2 seconds and dies won't fire again till you ready to set it on fire just bought a new carb same as the one it had reeds are good,125psi it has spark everything checks out like it should some one please help
Old Jul 9, 2018 | 11:02 PM
jaguar57's Avatar
125psi compression is low which means you need new rings (assuming the head gasket is sealing correctly)
Use new gas
spray soapy water on the ignition side crank seal and kick the engine over to check for bubbles (after removing the spark plug and while pressing the kill button) If there are bubbles then the seals need to be changed.
arj39
Aug 13, 2019 02:55 AM
Nickfree4767
Oct 25, 2017 11:11 PM
FordPrefect
Jul 26, 2009 05:24 PM
henryhoehandle
Sep 20, 2006 11:21 PM
motoman
Jan 9, 2006 03:05 AM
