06 250 Ninja
Old Sep 23, 2013 | 09:21 PM
archer6831's Avatar
Default 06 250 Ninja
I have been working on my daughter-in-laws bike. After riding it for roughly 15min or so it would start bucking then had no power to pull out. I thought it was a fuel system issue but found nothing wrong. Turns out that the previous own had put some led accent lights on it an a wire was grounding out on the frame. Fixed the short and it was fine for a couple days, then it started again. I started thinking that the short might have fried the stator. So, I checked the voltage output on the stator. When testing it on the 3 yellow wires coming from the stator I get 6.9 volts on all 3 wires @1500 rpm. But, I only get 4.9 volts @ 3000 rpm. Shouldnt that be the other way around and shouldnt those readings be higher ??? And if so, what would be the cause ?
PvtCaboose
Ninja 250R
Aug 11, 2013 08:31 PM
adrian2779
Apr 7, 2012 10:28 PM
Cropduster21
Nov 28, 2007 04:36 PM
Fever
Feb 21, 2007 02:20 AM
Icantrideabike
Jul 1, 2006 09:18 AM
