05 Brute 750 Idle Issues
Old Mar 16, 2010 | 08:10 PM
SKCAS1's Avatar
Default 05 Brute 750 Idle Issues
I have an 05 Brute Force 750 that is having some idling issues. I have owned the bike since new, it has no mods on it. The only thing that has been done is the carb needle recall when it was new. The bike has been ridden hard but has sat quite a bit for the last two years, with occasional starting. Due to the large amount of snow here in the northeast this year it saw a lot of action. The problem I am having is the bike will not idle. It will only run with the choke on and backfires constantly. I changed the plugs but it just keeps fouling them. It starts ok and ran well enough to push snow but needs to be fixed and i am not sure where to start with it? Does anyone have suggestions? I am pretty sure it is a carb issue but want to get some feedback to see if anyone else has dealt with this.
Thanks
Old Mar 17, 2010 | 06:29 AM
Welcome to KF.
I would drain the bowls and check for water and sediment. (never played with a brute force). Good luck
Old Mar 17, 2010 | 04:23 PM
jeffzx9's Avatar
+1^ Drag. Start easy; drain the gas out of everything and start fresh. If that doesn't do it (and it may not,) you'll need to pull the carb(s) and manually clean the little holes in the jets and needles.
Keep us posted.
scrooge
Jul 4, 2007 11:45 AM
scrooge
Feb 22, 2007 05:38 PM
scrooge
Feb 4, 2007 02:40 PM
knot2wise
Jan 29, 2007 09:49 PM
sbowling79
Dec 19, 2006 08:12 PM
