'03 ZR-7 engine is very upset
Old 08-13-2018, 11:31 PM
Logan Cormier's Avatar
Default '03 ZR-7 engine is very upset
Got an inline-4, oil cooled Kawi a couple weeks back. 20,000mi, stored for a few years and carbs rebuilt by owner. Was fairly well cared for. Light issues with the carbs - probably a slightly sticky float valve. Previous owner had no significant problems and was diligent with maintenance. Noticed a little ticking a week into riding, but not severe. One of the exhaust pipes isn't discolored from heat like the other 3. Was su****ious I wasn't getting quiiite the MPG or performance I should. Second week riding, after a long ride largely through cities (toasty engine, running fine), left it off for ~30 mins and had a looot of trouble getting it to start and not die idling. Barely made it home; Would die out if given more than 1/3 throttle, and had to adjust idle significantly higher to keep it from dying. Checked oil, which had just been changed a couple weeks back: Dirty as hell. Previous oil changes were completely clean, but changed early anyway.
What should I check for when I open it up?
How much can I accomplish myself through research and careful work?
Side question: Would it be possible or realistic to rip an EFI system off a junked 4 cylinder bike and install it on my carbureted inline 4?
Any suggestions appreciated. Thanks.
Old 08-20-2018, 11:12 PM
Rob9876's Avatar
About the only active discussions on this forum revolve around KLX 250S bikes. You may have better luck at this forum:
lhemrick
03-07-2019 03:58 PM
Fog
Ninja ZX-14
10-17-2018 06:58 PM
Daignostic
08-29-2018 12:24 PM
Incredible4Mr2E
08-09-2018 11:00 PM
Parker Shellhammer
Classic Sportbikes
06-07-2018 03:40 PM
Quick Reply: '03 ZR-7 engine is very upset
