1984 zn700?
1984 zn700?
I have a 1984 ZN700 with CV type carbs. It is stock except I am using pod filters. The bike is sluggish when you get in the throttle and when coming off a high throttle position with the grip it takes it more time than normal to return to a proper idle. What could be the issue?
About the only active discussions on this forum revolve around KLX 250S bikes. You may have better luck at this forum:
https://www.kawasakimotorcycle.org/
