´82 Kawasaki 440 LTD - 13 Yrs In Storage - Pre Start-up Recommendations
Old Apr 14, 2012 | 10:27 AM
Danno2cu's Avatar
Default ´82 Kawasaki 440 LTD - 13 Yrs In Storage - Pre Start-up Recommendations
Hello,
I recently inherited a ´82 Kawasaki 440 LTD that has been sitting under a blanket, in a garage for 13 years. When it was put in the garage, 13 years ago, no storage preparations were done to it (i.e. fuel still in tank, etc.)
I would put myself at somewhere between beginner and average in terms of my mechanical skill / knowledge. I know enough to not charge up the battery and hit the start button after such a long storage period. My instincts tell me that, at the very least, I should:
  1. Drain & flush the fuel tank / lines
  2. Change the oil
  3. Replace the spark plugs (and after the old plugs come out, before the new ones go in)
  4. Spray some lubricant into the spark plug holes
  5. Replace fuel, air & oil filters
What else is recommended to prep the engine before I attempt to fire it up after an extended time in storage?
Thanks for the help!
Dan
Old Apr 14, 2012 | 11:35 PM
Sounds like a good plan. You may want to let the lubricant sit in the cylinders for a day or so, then turn the engine over by hand and not with the starter.
You may find that the rubber carb boots are cracked and need replaced.
Get some brake fluid to flush out both ends of the brake system.
Get a new battery and tires. Remove the chain and soak over night in kerosene or diesel. Or inspect and replace the belt drive. (not sure what the LTD used)
Welcome to KF
nkd288
Feb 26, 2013 09:24 PM
hillbilly
Jun 1, 2007 11:00 AM
Nitrospaz19
Jul 30, 2006 06:03 AM
Nitrospaz19
Jul 26, 2006 08:08 AM
ZX_9r
500 LTD
Jan 19, 2006 03:04 AM
