surface rust
Old 04-14-2008, 02:49 AM
sg1982's Avatar
Default surface rust
can any one tell me what the best way to clean sufacerust off rotors and chain
Old 04-14-2008, 03:44 AM
j_christopherhall's Avatar
Default RE: surface rust
You can actually get a little u-shaped wire-bristled brush designed to get three sides of the chain cleaned at the same time. Otherwise its tough to get that inner side of the chain without removing it entirely. Maybe 15 bucks and comes with some de-greaser fluid to get the grease and otherbuild-up(including rust)off the chain and then put some chain lubricant on it. Works well actually. The manual on my bike says to clean and lube the chain every 600 miles and Iactually do that, or pretty close to it. Rust comes off the rotors as quickly as it builds up just bytaking the bike for a decent lengthspin, at least in my experience, so I haven't worried about that. I'd imagine you could take that de-greaser fluid to the rotors toget rust off thembut you might want to check the instructions on the bottle first just to make sure you're not inadvertantly destroying them(I'd be very surprised if that were the case, though, its not like its corrosive stuff like paint-stripper, just cleaning fluid).
Old 04-14-2008, 04:36 AM
markmeinteil's Avatar
For the rotors, I would use a fine 3M roloc disc or a wire wheel to remove any rust. taking off the rotors would be the most proper way to do this.
Old 04-14-2008, 08:12 AM
niklucas's Avatar
BTW, if you want a decent, environmentally friendly (in a way) anti-corrosive liquid which would help remove it from metal surfaces, I'd suggest Coke.It contains so much phosphoric acid that it does the trick even better then a whole lot of other anti corrosive stuff. Just do n't forget to wash it off
Old 04-14-2008, 12:40 PM
wd40 works good to get grime off chains too.....
Old 04-15-2008, 06:54 AM
whitehendrix's Avatar
steel wool is baller
Team FTB
05-26-2007 02:03 PM
Ratkiller
04-25-2007 10:01 PM
Marty
01-18-2006 05:30 PM
KORNOLIO
12-05-2005 11:46 PM
pdrury
10-19-2005 06:17 PM
Quick Reply: surface rust
