advice - 09 klx250 with b&b 351 big bore kit
Old Oct 10, 2009 | 03:16 PM
BOXY's Avatar
Default advice - 09 klx250 with b&b 351 big bore kit
This is my first post ever, and I could use a little advice.
Just bought an 09 klx250s with a b&b 351 big bore kit and mikuni pumper installed. The bike works well but I am concerned about longevity. It seems to run real hot. Has anyone had any long term experience with this set up?
It still has the stock exhaust.
Any advice, comments or observations would be appreciated
Thanks
Old Oct 10, 2009 | 03:24 PM
Welcome to KF.
Check out the klx section, and do a search. There has been a few big bore mods done. Just not sure if they were of the 351cc. Good luck.
Old Oct 10, 2009 | 03:52 PM
95451's Avatar
Welcome To Kawasaki Forums.
Turn On Some Tunes And Enjoy The Ride.
Old Oct 11, 2009 | 09:04 PM
BOXY's Avatar
Thanks for the help guys, I'll keep lookin
BOXY
Old Oct 12, 2009 | 06:31 AM
MaverickAus's Avatar
Might be a bit lean, have a look in the KLX250 section
Old Oct 13, 2009 | 01:50 AM
buffalony's Avatar
Check the carb for proper setup. make sure your getting the mixture of fuel. You can try replacing the stock exhaust. Many after market exhaust systems are designed to allow more air-flow and better heat disipation, which makes the bike run cooler.
Old Oct 13, 2009 | 10:13 PM
BOXY's Avatar
Thanks for your input guys. I'm already lookin into a proper exhaust system
That should help a lot.
Old Oct 14, 2009 | 05:13 AM
wedge's Avatar
Whats "HOT" ???
I would only be worried if.. the Radiator fan doesn't come on....... or its on all the time
or the indicator is always in the "red".
Have fun and just ride it! keep the rubber side down....
oh...... BTW-- WELCOME to the forum!
jonathan76
Sep 22, 2011 01:58 AM
mattyw
Oct 2, 2009 02:02 PM
punkenduro09
May 6, 2009 07:53 PM
maniac
May 26, 2007 12:36 PM
