advice - 09 klx250 with b&b 351 big bore kit
This is my first post ever, and I could use a little advice.
Just bought an 09 klx250s with a b&b 351 big bore kit and mikuni pumper installed. The bike works well but I am concerned about longevity. It seems to run real hot. Has anyone had any long term experience with this set up?
It still has the stock exhaust.
Any advice, comments or observations would be appreciated
Thanks
Thanks
Check the carb for proper setup. make sure your getting the mixture of fuel. You can try replacing the stock exhaust. Many after market exhaust systems are designed to allow more air-flow and better heat disipation, which makes the bike run cooler.
Whats "HOT" ???
I would only be worried if.. the Radiator fan doesn't come on....... or its on all the time
or the indicator is always in the "red".
Have fun and just ride it! keep the rubber side down....
oh...... BTW-- WELCOME to the forum!
jonathan76
Sep 22, 2011 01:58 AM
jhoffy22
Jun 18, 2011 12:17 AM
