650r problems
just did an oil change and the oil looks like a milkshake anyone have any idea why ? Also there is a weird noise coming from the crank every time I try to start it. Can some one point me in the right direction. ?
Milky oil is usually an indication that it's contaminated, likely with water or coolant. It may have a failed water pump seal, or maybe something worse. This may or not have caused the crank noise problem. Is it losing coolant? Has it sat for a long time?
I'd change the oil and filter right away. Cut the filter open and look for metal shavings. Watch the coolant level very closely and further diagnose the problem.
