Need help got a engine issue
Old Mar 31, 2009 | 07:36 AM
santiboricua's Avatar
Exclamation Need help got a engine issue
First off I will try to make this short, and to the point.
2005 ZX6R 636
About 5 months ago my buddy hit a deer about 30 mph and went down on his right side, visible damage was cosmetic fering stuff, and a small crack on the clutch cover in which some oil drained out of. He had the bike towed due to the loss of oil. So currently he replaced the clutch cover and changed the oil, and took it out for a test drive in which after a few minutes the engine was knocking. He brings it back to his house where he checks the oil, and finds the oil to of turn into "chocolate milk", as if it has water or coolant mixed into it. He drains and changes the oil again, and also replaces the the coolant, and takes it out again, all the knocking is all but gone but when he checks the oil again its back to that chocalate milk look again. So both of us are sure its some type of a internal leak, but figured I'd post it up and see if anybody has expierenced this before and what they did to fix it. Any suggestiones and ideas are very much appreciated.
Old Mar 31, 2009 | 08:02 AM
kevhamm's Avatar
mmm just drink it? i love chocolate milk. haha. even if coolant and oil did mix wouldnt it be like oil and water? hard to mix together? maybe not though.
Old Mar 31, 2009 | 12:07 PM
OMalley912's Avatar
If the oil is milky that's a bad sign. Woudn't even start it till someone chimes in with more tech info. Bummer about your luck.
Old Apr 1, 2009 | 01:13 AM
Didn't the 6r have a weak coolant pump O ring? Trying to remember if that was an issue or not now.
kevin292
KX100
Oct 11, 2012 01:37 AM
Israel-klx250s
Mar 4, 2012 08:33 AM
vegaas315
Classic Sportbikes
May 15, 2011 04:13 AM
MotorMac24
Jul 3, 2009 08:28 PM
