Gear Section Have some questions about the best safety gear for you? Ask it here!
arai visor change
Old Sep 14, 2006 | 07:52 PM
boostedintentions's Avatar
Default arai visor change
WTF?!?!?!?? What do you do..I can't get it off. No literature and I can't download the manual off their site for some reason.
Old Sep 14, 2006 | 08:22 PM
ZX12Rider's Avatar
Default RE: arai visor change
what model do you have? I'll see what I can find for ya, but I'll need to know the model
Old Sep 14, 2006 | 08:41 PM
ZX12Rider's Avatar
On the RX7 model......
Place helmet on table facing away from you
raise shield fully upward to deploy the levers
using both hands at the same time, push up and release levers until a click is heard from each lever
and then grasp the shield's sides and rotate your hands upward and away from the helmet which will remove the shield.
To replace....... hold the shield in approximately its fully open position, slip the comma shaped end of the shield into the side pod's front opening with the comma's lower edge riding on top of the wide white guide on top of the red latch fixture at the bottom of the side pod
Push the shield further into the side pod until the atop-tab on the lower edge of the comma shape goes over the white guide.
Work the shield end up and down, in and out slightly and gently to settle all areas into position. Repeat for the other side. The LRS lever automatically retracts as the shield is closed.
Old Sep 14, 2006 | 08:42 PM
ZX12Rider's Avatar
Oops, those instructions came from Arai's site - I was able to access the manuals.
Old Sep 15, 2006 | 05:00 AM
Notstock's Avatar
yep thats it.
Old Sep 15, 2006 | 03:40 PM
ZX12Rider's Avatar
Wonder how boosted made out getting the visor off????????
grey day
800, 800 Classic & 800 Drifter
Jul 11, 2008 04:42 PM
hoedogg
Nov 12, 2006 06:45 PM
KAWABUNGA
Jun 15, 2006 04:37 AM
importmonkey
Apr 12, 2006 04:56 PM
Eklipse636
Mar 26, 2006 10:04 PM
