DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your bike as told by your fellow members.
Stator Rewind KLX 250
Old Sep 16, 2019 | 09:19 PM
Jread's Avatar
Default Stator Rewind KLX 250
So I did a stator rewind on my 1995 KLX250 a year or two ago. Since then the bike has sat because I couldn't get it to make the lights work.
Recently I've done some reading about full wave rectifiers making it easier to wire. Was thinking of buying a new reg rec to rule that out of the equation and switch to a full wave to make it simpler to wire.
What I'm wondering is how I go about making the full wave work with my current winding. I alternate clockwise and counter but they are grouped into two groups of three. I assume if I tie one winding into the beginning of the other it should work. Coming out of the stator is just two yellow wires.
Also wondering if this will work on my bike with 5 wires? Is there a better and or cheaper option?
https://fortnine.ca/en/trail-tech-fu...off-7004-rr150
Old Apr 11, 2020 | 08:03 AM
Jread's Avatar
Anyone?
Old Apr 11, 2020 | 03:05 PM
Do you have/meet these mandatory items?
"Wire connection for use with most machines. DC stator and battery/capacitor sold separately.
Note: Trail Tech's Regulator/Rectifier is not an OEM replacement and will not work with most factory stators. The stator must have a floated ground, modifications to stator may be required."
Old Apr 11, 2020 | 05:42 PM
Jread's Avatar
I believe so but that's what I'm asking if my modification will give me the floated ground.
Kadin Wallner
Jul 9, 2019 07:37 AM
c.salt
Apr 3, 2018 04:20 PM
xxaarraa
Jan 30, 2013 12:12 PM
fgk228
Dec 22, 2009 12:33 AM
RaceGass
Dec 12, 2008 12:27 AM
