HELP! stator causing my starting problem?
Old Dec 20, 2009 | 08:23 AM
fgk228's Avatar
Default HELP! stator causing my starting problem?
yep it is.
the bolts had come loose and unwound all the way. 1 snapped and the other 2 were hitting inside the engine.
any ways to some damage had been done to the stator its self. couple of wires are broken on one side. is it worth me soldering them back to gether or just buying a new stator. sorry no photos camera is stuffing up
Old Dec 20, 2009 | 10:34 AM
fgk228's Avatar
soldered the stator back but it is fairly damaged. a new stator is 400 odd so im seeing if this works first
Old Dec 20, 2009 | 11:27 AM
neilaction's Avatar
Worth a crack for sure.
Can't hurt and it just might work.
Good luck.
Old Dec 20, 2009 | 02:57 PM
If you can't repair it yourself, you could call up some place like Trail Tech and I bet they'd fix it for a lot cheaper than you could buy a new one.
Old Dec 20, 2009 | 03:14 PM
lcpl0331's Avatar
Old Dec 21, 2009 | 12:23 AM
MaverickAus's Avatar
Good thought Brian but I doubt he wants to send it to the states for repair.
Old Dec 21, 2009 | 01:53 AM
Doh, totally missed the location. Surely there's someone in Aus that can do it, though.
Old Dec 21, 2009 | 02:11 AM
neilaction's Avatar
Yep there is.
And they will even increase the capacity if you want.
Just googled and this was at the top of the list.
http://www.bettabikes.com/services.html
Old Dec 21, 2009 | 04:22 AM
fgk228's Avatar
lcpl0331 FOR THE WIN!
part bought thanks for that. could'nt find it before
Old Dec 21, 2009 | 06:16 AM
neilaction's Avatar
I hope you are still going to have a crack at fixing the one you have?
Be interesting to see how you go.
