wiring a relay and switch for aux running lights
Old Jul 8, 2010 | 03:50 PM
clb3carl's Avatar
Smile wiring a relay and switch for aux running lights
hey all.........i know how to run wiring and do a switch....has any one ever used a relay on some aux/ fog lights and where did you pic up power from (battery?) --should the switch go on the neg side...any help would be great! thanks in advance...ps i burnt up my wiring to the 55 watt fogs lamps as there is too much draw with out a relay some where in there,.....just need to know how to wire the relay--- it has 4 terminals........kawa' 550 ltd 81'....40 k miles....bless her heart...she's running every day!!!!!!!!!!! still!
Old Jul 8, 2010 | 05:54 PM
I would add a dedicated fuse for the fog lamps to your switch. Not sure if you would need a relay for that although you could tie one into the circuit if you wanted. Battery, fuse, your rated switch, lamps, ground wire is how I am picturing this.
Old Jul 9, 2010 | 08:52 PM
Prom's Avatar
Running a relay would put alot more wires in the way, if you can get around it I would. You will need to increase the gauge on the wires to handle the lamps and get a switch that will handle the draw, and yes a fuse is a very good idea. If you have to use a relay your local auto parts place sells relay kits for offroad lights that will take care of it.
Old Jul 19, 2010 | 09:38 AM
clb3carl's Avatar
Smile just one more wire.....question about relay 4 fog lamps
thanks all!. i've got this all into my bike and for the most part wire up,..............just having a few questions as to where goes this last wire to get powered up---------.i do have heavy guage wiring on the power side going into the relay, after the relay there is less amp draw so you can use regular duty wiring no problem---- i understand this part-------..i've got the relay to the batt(wire 1) and ground(wire 2)...now, one wire says it goes to"aux" meaning my fog lamps of course(wire 3) ( that i will put in line with a fused switch) ---- the other wire from the relay says it goes to a switch(Wire 4)----this i am confused on.....i dont get this connection,,,i have wired a similiar project to my truck...fogs lamps, relay, fuse, switch and even a cool neon indicator lamp that shows when my fogs lamps are burning when i hit the floor switch...but the relay was a different configuration {5 wires} and it took the rest of my brain cells i guess to get er done that time....thanks in advance for any helpers out there___________ i love my bike!...she's old, a little battle scarred, but still my best friend...(and my dog)...
Attached Thumbnails wiring a relay and switch for aux running lights-schematic4.jpg
Old Jul 19, 2010 | 07:26 PM
Prom's Avatar
If I am understanding you properly you put a switch between the relay and the fog lights, in which case your doing it wrong. The relay is simply a switch to turn a high power unit on and off, you then must activate the relay using a separate switch so you must make 2 different circuts.
Using your diagram you must make the first circut by going from a power source to the switch then to relay connection #1 then relay connection #2 to ground. This will turn the relay on and off.
The second circut will go battery then fuse then relay connection #3 then from relay connection #5 (what happened to 4?) to your fog lights then to ground. This entire circut must be made with heavy gauge wire, you can not use a smaller gauge after the relay.
The purpose of this is to activate a high power device using a low power circut, good luck!
David Larocque
Dec 1, 2013 05:00 PM
RobG
May 16, 2012 04:38 PM
69svt
May 6, 2009 12:52 AM
punkenduro09
Feb 20, 2009 12:55 PM
