1980 Kawasaki KZ440 Clutch Problem
Old 10-22-2009, 12:28 AM
supertramp105's Avatar
Default 1980 Kawasaki KZ440 Clutch Problem
i recently replaced the clutch cable. afterwards, i noticed that the clutch was engaging some with the lever squeezed. i tried to adjust it according to my book and something snapped inside the housing. now i have no tension whatsoever.
Old 10-22-2009, 12:32 AM
95451's Avatar
Welcome To Kawasaki Forums.
Turn On Some Tunes And Enjoy The Ride.
They're a lot of Good Members Here and they will do there Best to Help You out with Your Questions. Sometimes It Takes A Little Longer Then Others. So, hang-in there.
Old 10-22-2009, 02:38 AM
check the threaded adjuster to make sure that it did not seperate there as in it may have been adjusted too loose. good luck.
Welcome to KF.
chriswilhelmart
Classic Sportbikes
11-12-2014 12:48 AM
DevanSean
03-17-2013 05:51 AM
greatwarfilm
Classic Sportbikes
05-04-2009 10:28 PM
rodman_38
Classic Sportbikes
02-16-2009 03:35 AM
thetinman69
Classic Touring Bikes
06-23-2007 04:00 AM
Quick Reply: 1980 Kawasaki KZ440 Clutch Problem
