1980 Kawasaki KZ440 Clutch Problem
i recently replaced the clutch cable. afterwards, i noticed that the clutch was engaging some with the lever squeezed. i tried to adjust it according to my book and something snapped inside the housing. now i have no tension whatsoever.
Welcome To Kawasaki Forums.
Turn On Some Tunes And Enjoy The Ride. They're a lot of Good Members Here and they will do there Best to Help You out with Your Questions. Sometimes It Takes A Little Longer Then Others. So, hang-in there.:) |
check the threaded adjuster to make sure that it did not seperate there as in it may have been adjusted too loose. good luck.
Welcome to KF. |
