1983 kz 750 4cyl.
Old May 20, 2007 | 03:46 AM
biggie's Avatar
Default 1983 kz 750 4cyl.
Hi, i am new around here but i recently purchased my kz and there seems to be a chargin system issue. with a dvom on the battery while running with increased rpm i do not even manage to get over i volt above battery voltage. Is this normal? does any one have any sugestions. i have tested the batery numerous times and this tested fine.
thanx in advance,
dc
Old May 22, 2007 | 10:41 PM
biggie's Avatar
Default RE: 1983 kz 750 4cyl.
Well i was hopen someone may have my anser however it seems they do not. does anyone possibly know where i may find this information out?
[align=left] [/align]
Old May 23, 2007 | 01:18 AM
Bluebeast's Avatar
it sounds like you have a bad stator or some thing else. not to great on trouble shooting electrical problems.
Old May 23, 2007 | 09:12 PM
biggie's Avatar
thanx a million
Old Jun 24, 2007 | 08:09 PM
biggie's Avatar
Old Jun 27, 2007 | 02:58 PM
mrmoto876's Avatar
Check the acv output from stator. should be about 75 vac between 2 leads at 4000 rpm.If ok, make sure there is battery voltage on white wire at reg/rec, and battery voltage on brn wire with key on. the blk/yellow wire will also need a good ground. if all checks out, will a reg rectifier. would also make sure the stator wores are not pinched in the sprocket cover.
wakeboarder82420
Jun 29, 2009 03:31 PM
espacef1fan
Jul 13, 2008 12:25 AM
Hawken
Nov 26, 2007 12:08 AM
biggie
Classic Touring Bikes
Jun 21, 2007 10:18 PM
