Wider rear tire possible?
I'm awaiting delivery of my new 2006 Nomad and am wondering if there's a wider rear tire that'll fit without having to modify this 'n that or will screw up X,Y, and Z ??? And, on the same note, is there a tire size (front, rear, front/rear combo) that will correct the speedo error from the factory?
Thanks again!!!
Daryl[:-]
Thanks again!!!
Daryl[:-]
It is possible, however you have to change the swing are and everything else. Nomads are not made to go with the 240 rear tire. They are a touring bike. You may get away with a180 or 190 for a rear but you are going to be limited. with sizes. There is not much out there for Kawasaki Nomad's. I just switched my 05 1600 Nomad Tires with Metzelers Wide White Wall tires and had to go down in size for the rear. So instead of the 170/70/16 I had to go with 150/80/16. Not much out there. Keep asking questions and even call Metezler, Avon, Dunlop, and the other mfgs. They will talk to you about tire sizes for your bike. I was surprised when I was looking and decided to call. Aske for a Tech and they will spend the time to tell you what they know about fitment and recommendations. Worked for me.
