2009 KLX140L will only start in Neutral
Old 04-08-2016, 04:18 AM
FrankCastle's Avatar
Question 2009 KLX140L will only start in Neutral
Does anyone know how to get around this?
My KLX140L will only start if it's in neutral. It doesn't matter if the kickstand is up or the clutch is in, it just won't do anything til you put it in neutral, which frankly can be a pain sometimes to find out in the woods.
Can anyone help me? Thanks!
Old 04-08-2016, 03:47 PM
My KLR did this.
It was a stuck clutch safety switch.
Old 04-09-2016, 08:34 PM
Default clutch switch
I tried that, seems fine. Do I just arch the wires across to close the circuit and try that to rule it out?
thanks for the help.
Old 04-10-2016, 06:24 PM
Something like that...
I pulled the safety switch from the KLX clutch and repaired the one on the KLR.
I don't recall if the switch needs to be open (disconnected) or closed (connected) for it to work. Try both, do some research, or ... from what I recall just looking at the switches when I was in there made it obvious.
Straightroosting87
04-25-2014 02:33 AM
revhappy
11-20-2008 01:45 PM
bwake 5
11-15-2007 03:34 AM
Jutboy
02-16-2006 02:39 AM
Quick Reply: 2009 KLX140L will only start in Neutral
