Ignition advance
Old Jan 9, 2009 | 08:12 PM
BLKPEARL's Avatar
Thumbs up
You got it bro!
Old Jan 13, 2009 | 07:39 PM
BLKPEARL's Avatar
The advancer got here today. Here's a picture of what's going on. Haven't done too much of a test ride yet, but the throttle response is a bit better, and will rev a bit quicker.
I really just need to bite the bullet and do the jet kit.
Old Jan 14, 2009 | 04:53 AM
zzrick's Avatar
Mine still isn't in yet. Any special tools required? How long for install? It looks pretty "cut and dry", but is there anything I should know?
Old Jan 14, 2009 | 12:35 PM
BLKPEARL's Avatar
Thumbs up
It's pretty cut and dry. There's like 6 8mm bolts to be removed. The one at the very top of the case was loc-tighted. There is a gasket on there, so be kind of careful when you remove the case unless you have a spare. There is a 17mm nut that holds the timing wheel on. When you go to turn it, I think the cams will move. Mine did a little. Since I didn't have a hammer here, I used a 4 D cell mag light to hit the end of my 1/2" drive to loosen the nut. The gear piece just slides off. If you look at the splines, there's only one way off and one way on. It can't be screwed up. You'll see. To tighten the nut back on, I ended up tapping the wrench to snug it. I've heard of people trying to use a screw driver to hold the gear. I've also heard of the gear getting broken that way.
Rick---any more questions, let me know. If you want, I'll email you my phone #.
Old Jan 14, 2009 | 02:14 PM
zzrick's Avatar
MIne still won't be here for a few days. I will try to get it on this weekend while there is a bunch of snow outside. Maybe I can fit it in somewhere between CHem and trig homework
Old Feb 8, 2009 | 12:48 AM
zzrick's Avatar
Installed mine today. You were right...very easy job. Took me about 15 minutes total. For anyone else doing this, one piece of advice would be to leave it on the side stand. My bike was on the stands and a little (very small) amount of oil came out. I think if it is on the side stand it would not leak any at all. Didn't have a chance to ride it yet, so no report on performance gains.
darkmarc
Jun 17, 2013 03:51 AM
jimmy101
Jul 26, 2011 05:30 AM
jhoffy22
Jul 25, 2011 05:15 AM
Peter Laurie
Mar 12, 2011 02:21 AM
Kspin
Jan 20, 2006 02:28 AM
