Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
need some info on rebuild
Old Mar 20, 2008 | 04:54 AM
mikezx6r's Avatar
Default need some info on rebuild
ok so i have a 01 zx6r and want to rebuild it but i wanted to put some performance parts into it any suggestions on the best parts? any comments on boring the cylinders?
Old Mar 21, 2008 | 08:00 AM
whitehendrix's Avatar
Default RE: need some info on rebuild
boring is fine..
how much you wanna spend bro?
i'm doing JE slugs and carillo rods.
pauter, carrillo, JE, wiseco, and a few other companies are great..
web cams and muzzy..
are you going to bore or sleeve yourself? you know how to do it? its not that hard to sleeve..
i'm personally going with SI valves.. great stuff for half the price of ferrea.
i dunno man.. what hp are ya shooting for.. theres a TON of things you can do that are free or cheap...
just simple things, like making a crank scraper and windage tray, kleen air blockoff and vent mods, and opening the windows between the cylinders for better pressure equalization can net significant gains.
map blow-by with a flow meter on a dyno, and gap your second ring accordingly to compensate for ring flutter. closer gap=higher rpm the flutter occurs..
degree your cams
backcut your gears (maybe..) sometimes this is bad.. do research first!
i dunno man.. cheap, fast and reliable.. pick two.. lol
[8D]
Old Mar 21, 2008 | 10:06 PM
ezrollin's Avatar
I pick... fast, fast and fast!
what are slugs? lifters?
You said its an 01? How much mileage?
You didnt say it was broke.
Its spring break you should be riding not rebuilding!
Old Mar 22, 2008 | 12:18 AM
mikezx6r's Avatar
yea im not rebuilding yet ill wait till after riding season but i want to get parts and a basic game plan on what im going to do
Old Jun 17, 2008 | 03:08 AM
768 Ryda's Avatar
u could put some 636 pistons in your block, do the head and do a cam swap while u are at it
seth6025
Jul 21, 2010 07:50 PM
cbr1000x
Jul 25, 2008 02:49 AM
teamsnapple
Apr 7, 2008 02:34 PM
werken247
Aug 10, 2007 03:01 AM
Ninja Honey
Ninja 500R
Jun 28, 2005 05:52 PM
