Got my baby some gifts.....
Overall Length (2)
76.2 in.
1935 mm
Overall Width (3)
28.2 in.
715 mm
Seat Height:
Standard (4)
30.5 in.
775 mm
Low Profile
Ground Clearance (2)
4.35 in.
110 mm
Rake (at Steering Head) (4)
21.0°
21.0°
Fork Angle (4)
21.0°
21.0°
Lean Angle:
Soft Contact, Right (5)
47°
47°
Soft Contact, Left (5)
47°
47°
Hard Contact, Right (5)
50°
50°
Hard Contact, Left (5)
48°
48°
Trail (4)
3.3 in.
83 mm
Wheelbase (2)
52.0 in.
1320 mm
Tires:
Type (6)
Pirelli®
Pirelli®
Front
Diablo T (model)
Diablo T (model)
120/70 ZR-17 (specifications)
Rear
Diablo T (model)
Diablo T (model)
180/55 ZR-17 (specifications)
Fuel Capacity
3.82 gal.
14.5 L
Reserve Fuel Capacity
0.75 gal.
2.8 L
MPG (EPA urban/highway test) (7):
Urban
48 MPG
4.9 L/100 km
Highway
65 MPG
3.6 L/100 km
Weight:
Dry Weight
395 lbs.
179 kg
Gross Rating
850 lbs.
386 kg
Load Capacity
388 lbs.
176 kg
Top of Page
Engine
U.S. Units
Metric Units
Engine
Air/oil/fan-cooled, 4-stroke, 45° V-Twin
Valve Train
OHV, two valves per cylinder, self-adjusting
Bore x Stroke:
Bore
3.500 in.
88.90 mm
Stroke
3.812 in.
96.82 mm
Displacement
73.4 cu. in.
1203 cc
Compression Ratio
10.0:1
10.0:1
Fuel Delivery
49 mm down draft DDFI II fuel injection
Intake (Air Cleaner for Blast®)
Zero-resistance airbox
Exhaust
Tuned, tri-pass resonance chamber with InterActive valve and mass-centralized mounting
Torque (North America per SAE J607)
84 ft. lbs. @ 6000 RPM
113 NM @ 6000 RPM
Horsepower (North America per SAE J607)
103 HP @ 6800 RPM
103 HP @ 6800 RPM
Lubrication
Dry-sump
Dry-sump
Oil Capacity (Lubrication for Blast®)
2.5 qts.
2.4 L
Oil Filtration
Screw-on disposable element
Top of Page
Drivetrain
U.S. Units
Metric Units
Primary Drive
Chain, 1.500:1 (57/38) ratio
Final Drive (8)
Constant path, 14 mm pitch aramid-reinforced Goodyear® Hibrex® belt with Flexten® Plus technology, 2.407:1 (65/27) ratio
Clutch
Wet, multi-plate, compensated
Transmission
5-speed, helical gear
Overall Ratio:
1st
2.648
2.648
2nd
1.892
1.892
3rd
1.407
1.407
4th
1.166
1.166
5th
1.000
1.000
Top of Page
Chassis(6)
U.S. Units
Metric Units
Frame
Aluminum frame with Uniplanar™ powertrain vibration isolation system, fuel in frame
Front Fork (6)
43 mm Showa® inverted forks with adjustable compression damping, rebound damping and spring preload
Rear Shock (6)
Showa® coil-over monoshock with remote, under-seat reservoir and adjustable compression damping, rebound damping and spring preload
Wheels:
Color
Cherry Bomb Translucent (new) or Designer Black Powdercoat (new)
Front
6-spoke, ZTL™ cast aluminum (type)
17 in. (diameter)
432 mm (diameter)
3.5 in. (width)
89 mm (width)
Rear
6-spoke, cast aluminum (type)
17 in. (diameter)
432 mm (diameter)
5.5 in. (width)
140 mm (width)
Brakes:
Front
ZTL™-type brake, 6-piston, fixed caliper, 375 mm single sided, inside out, stainless steel, floating rotor
Rear
Single piston, floating caliper; 240 mm stainless steel, fixed rotor
Suspension Travel:
Front
4.72 in.
120 mm
Rear
5.00 in.
127 mm
Top of Page
Electric
U.S. Units
Metric Units
Battery
Sealed lead acid, maintenance-free, 12V, 12 amp/hour, 200 cca (per Battery Council International Rating)
Charging
38-amp, permanent magnet, 3-phase alternator with solid-state regulator (481W @3000 rpm, 494W peak)
Starting
1.2 kW electric with solenoid shift starter motor engagement
Lights: (as per country regulation)
Headlamps Type
Twin projector beam[H3]
Headlamps Description
55-watt low beam, 55-watt high beam
Tail/Stop Lights
5W/21W
5W/21W
Turn Signal Lights
10W manual canceling
License Plate Light
5W
5W
Top of Page
Styling/Convenience
U.S. Units
Metri
