Attention computer gurus! Word Help
OK first off with the ammount of times you have reloaded, That computer must be bloody strong.
Now. When you hit print, go to the menu and hit it, dont just hit the button up top. Once you have done that it should show a screen full of printer settings and such. Down in the left bottom of this window there is a menu that says "print what" make sure it is set to "document" instead of anything else. Then go into properties (top right) and it will open another window. Look through those settings and make sure paper is set to A4 and says plain paper. And also that there are no other settings that may screw it up. After that go back to the original print box by clicking "OK" and back in the bottom left hand corner click "Options" and it will open another screen. Make sure in "Printing Options" that the only selected setting will be "Print Drawings created in word" If this doesn't work then unistall your printer and unplug it then reinstall it and plug it back in.
If that doesn't work then i suggest you go ahead with your other plan and shoot your computer
Let us know how that goes.
ORIGINAL: AzzDawg
In your last instruction to check the options in the lower rt corner I noticed a box checked saying "include document properties" unchecked that bioatch and F-ing A we got it.
Thanks bro you are the freaking man. [sm=icon_cheers.gif]
