Acetone For Better Mileage...
Old May 27, 2008 | 04:08 AM
klx250s_rider's Avatar
Default Acetone For Better Mileage...
I know a lot of you have heard and possibly experimented with using 2 oz. of acetone to 10 gallons of gas for improved mileage and performance - Seems to be a lot more information, both pro and con on the web since gas sky rocketed. I recently read one of these articles at http://peswiki.com/index.php/Directo..._Fuel_Additive.
and on AutoBlog.com at http://www.autoblog.com/2005/09/24/a...e-gas-mileage/
Do you have any feedback on adding acetone to your tank of gas?
Old May 27, 2008 | 05:38 AM
BigRig18Wheeler's Avatar
Default RE: Acetone For Better Mileage...
I haven't tried it myself.... But to post an opinion, it would probably help in older cars, only because of the increased flammability, reducing spark knock, detonation, etc.... And it would probably clean out the carbs, injectors, carbon off the vavles. Etc....
On those types of cars where acetone might help, berryman b12 or any good carb/injector cleaner would probably do the same thing on a short term testing basis. IMO anyway.
I think no matter what you add to your gas, unless it cleans out the motor ( carbon, deposts, sludge, etc ) your car would still get close to the same mileage because nothing in the actual carb/ fuel injection circuit is being changed. The same amount of air and the same amount of fuel is going to pump thru the carbs unless you change the jetting in the carb, etc..
Old May 27, 2008 | 06:22 AM
You can also change your driving habits to save gas, so called Hypermiling.
http://en.wikipedia.org/wiki/Fuel_ec...zing_behaviors
http://www.gasolinecreditcards.com/e...and-resources/
Old May 27, 2008 | 10:36 AM
kx slaughter king's Avatar
and engine oil with low-kinematic viscosity[1] referred to as low "weight" motor oil, which is filled just to the low-level mark
yeah.... lets increase our effiency by 2%, then pay $10,000 in 2 years to replace your seized block[sm=bangbang.gif]
Ranger Ron
Oct 7, 2013 04:49 PM
95zx6rGuy
Jul 19, 2007 10:07 PM
Notstock
Jan 12, 2006 08:38 AM
Violet_Vixen
Nov 4, 2005 10:58 PM
TATTOOZIT
Jun 21, 2005 04:44 AM
