Off Road Taken your quad or bike off roading lately? Talk about it here.
KSF250 Timing
Old May 16, 2012 | 07:14 PM
andwhat03's Avatar
Default KSF250 Timing
Hi all, I replaced the head and cams on my KSF250 with a used set and having issues with timing and compression and starting. Lets start with timing.
Which is the timing mark on the Magneto? Is it the "T"? or is it the notch to the left of the T?
If everything is apart do i still have to worry about the compression stroke? If yes, How do I find it if everything is already off?
After assembling everything I performed a compression test and it goes BLOOP through the exhaust and i get no more than 30lbs. I performed a leakdown test with a compressor set to 60lbs and it holds compression at TDC. I'm thinking KACR. True? or maybe I'm timed 180deg. off?
Thanks in advance
Old May 17, 2012 | 02:03 AM
Hit up your search for the KACR in the KLX section. There have been issues and some recommendations.
Welcome to KF
Jul 1, 2011 02:43 AM
gregb
Jun 24, 2008 10:21 PM
kawibanshee
Jun 14, 2007 07:07 PM
thecount
Mar 13, 2006 07:14 AM
tiger
Ninja ZX-10R
Sep 25, 2005 08:22 AM
