Off Road Taken your quad or bike off roading lately? Talk about it here.
2006 Kawasaki KX250F sticky throttle
Old Mar 11, 2023 | 09:05 PM
The_urban_mechanic's Avatar
Default 2006 Kawasaki KX250F sticky throttle
Hi guys! I have a 2006 Kawasaki KX250F! I picked it up on marketplace blown up for 1200$, it was the cheapest deal in my area. Rebuilt it according to factory spec, new all ballz bearings, hot rods crank with a vertex piston. Installed new valve seals and checked my valves, they sealed and looked good (I do need to shim them properly though, they are loose a few thou.) All and all, the bike had everything but a carb rebuild. Fired it up and ended up tuning it in. The bike also has a powercore 4 on it, with a new gasket. The joint seems strong between the pipe and the header. Main-190, leak-42 and the idle was stock if I'm not mistaken. Replaced my fuel screw. The bike idles like a dream, revs up quickly and has a lot of power, but for whatever reason the throttle sticks? It just likes to rev up and act like I'm holding the throttle a quarter or so open, even after closing it. If I jockey the throttle it goes back to a normal, slower but not too slow idle. Cables are quite loose and free, no sign of the slide sticking. Everything seems like it's installed correctly according to the factory manual, and I was told by the previous owner it did have the same problem before he blew it up. No misfiring, no other obvious issues. I'm stumped. Same symptoms if I swap in a 178 jet. Plug looks great at a 178, however. Pulled the carb apart last week and found no sign of anything wonky, but the wheels did wear two streaks in the side of the FCR and seemed a little loose with play.
Mike112
Feb 22, 2019 08:50 PM
Craig Gast
KX250 & KX250F
Jul 6, 2017 01:37 AM
stuntman
May 31, 2017 03:45 AM
362dad
Sep 5, 2012 12:30 PM
kx250f
Dec 21, 2011 10:09 PM
