shaking front wheel
Old 02-13-2013, 10:44 PM
9rguy's Avatar
Default shaking front wheel
Hi, I need some info on where the problem might be. My tire is in about 60% condition,no brake binding(free spinning wheel) but if I let go of the handlebars at 50kph or higher there is a shaking/wobbling of about 2 inches on the front wheel.Can anybody give me a list of things to check?
Old 02-13-2013, 11:26 PM
Dark Angel's Avatar
If you're lowered the front end (raised the forks in the clamps to get a steeper steering angle and faster turn in) that could cause it, particularly with a worn tire.
Are the forks in the clamps evenly? (ie one not further through than the other)
Is the air pressure in the tire correct?
Have you thrown off any balance weights?
Is the rear suspension set right/working properly?
Are the head-stem bearings tensioned properly?
Are the swing-arm bearings in good condition?
Are you holding your mouth right?
Old 02-14-2013, 08:06 AM
Don't let go of the bars! lol
Those checks listed above are spot on. Even if a tire is at 60% does not mean that it has not already cupped or wore badly. How old is the tire?
Welcome to KF
Old 02-14-2013, 12:22 PM
jeffzx9's Avatar
Good suggestions^. Sounds crazy, but also check your REAR tire alignment...
Sid Post
01-27-2009 01:46 PM
vuskavich
Ninja ZX-10R
06-19-2007 04:41 AM
SliverR6
05-26-2006 03:55 PM
Dagon
01-09-2006 03:16 AM
PALYDIN11
Ninja ZX-12R
01-01-2006 02:32 AM
Quick Reply: shaking front wheel
