Hesitation/bogging problem on ZX-9 Naked
Old 10-02-2010, 05:08 PM
JBergland's Avatar
Default Hesitation/bogging problem on ZX-9 Naked
It was suggested to me to come here as there is a good deal of (accurate) info available. I have a '98 ZX-9 that I've converted to a naked... all panels have been removed. The air ducts on both sides of the tank have velocity stacks feeding air into the airbox. The breather tube that was on the orginal fairing/duct opening it positioned by the new headlight... it's still able to breath.
The is a pronounced hesitation bewteen 4-5K. If given more gas the engine will hesutate for a second, then come alive. The powerband is also fairly choppy.
There is some articles indicating that I may have a pressure issue in the airbox caused by some of the ducting changes? I may also need to do some re-jetting (very likely)?
What suggestions or advice can anyone offer??
Thank You!!
JB
Old 10-02-2010, 06:29 PM
That is just off idle throttle load in that range and generally the needle height/taper/spring is the culprit. Have you tried keeping the choke slightly on to see how the bike ran? Just an opinion since you have done extensive modifications to your ride. Good luck and Welcome to KF
Old 10-03-2010, 05:43 PM
JBergland's Avatar
Old 10-31-2010, 12:46 PM
wheel408's Avatar
Default I think I might know why
It has something to do with the fuel pump and the pressure, by removing the front air ducts you take that pressure away in that causing hesitation from here you could either go two ways recalibrate the carbs,needles or you could go the cheap route watch this video for a homemade fix http://www.youtube.com/watch?v=KtISwbsv-yc&sns=em I hope this works out for you
Old 11-03-2010, 02:41 AM
Thanks for the link wheel408
Old 11-19-2010, 01:16 AM
JBergland's Avatar
Thanks for the vid/link... it's given me some things to think about/consider. I have somecity stacks sticking out from where the old ducting went into tank/airbox... so I would think the pressure would chamge that much????
Thanks!!
JB
Old 11-27-2010, 02:21 PM
jeffzx9's Avatar
Hey, that's good!
That's got me thinking about my old '95. Mine's got larger rejetted carbs and gets on it (surprisingly well) up to about 100-105mph. Then it just hits a WALL. I still have at least a 1/4 turn of throttle, but it ain't happenin'. I suspected some air pressure issue (but have honestly been too lazy to pull it all apart.) You're putting ideas in my head...........
Thanks!
ballertrice15
11-29-2020 06:00 PM
Redrider2k2
06-10-2014 10:30 PM
kawikathy
11-21-2007 01:10 AM
zapitbullseye
09-21-2007 11:08 PM
Mott Power
Ninja 250R
12-19-2006 06:52 AM
Quick Reply: Hesitation/bogging problem on ZX-9 Naked
